alg [dns|facetime|ftp|pptp|sccp|sip|tftp]
                         alg  |
                     Enables traffic filtering at the application layer. The ALG provides filters for the following common protocols: DNS, Facetime, FTP, PPTP, SCCP, SIP, and TFTP. |
                         dns  |
                     Allows DNS (Domain
                           Name System) traffic through the firewall using its default ports.
                        This option is enabled by default. When enabled, you can easily permit or deny traffic based on a packet‘s DNS name, instead of the IP address. Use this option when configuring ACLs allowing or denying traffic for Web sites that have a single domain name resolving to any one of multiple IP addresses.  |
                         facetime  |
                     Allows Apple‘s FaceTime video calling traffic through the firewall using its default ports. This option is disabled by default. |
                         ftp  |
                     Allows FTP (File Transfer Protocol) traffic through the firewall using its default ports. This option is enabled by default. |
| pptp | Allows PPTP (Point-to-Point Tunneling Protocol) traffic through the firewall using its default ports. PPTP, a network protocol, enables secure transfer of data from a remote client to an enterprise server by encapsulating PPP packets into IP datagrams for transmission over the Internet or other public TCP/IP-based networks. This option is enabled by default. |
                         sccp  |
                     Allows SCCP (Signalling Connection Control Part) traffic through the firewall
                        using its default ports. This option is disabled by default. SCCP is a network protocol that provides routing, flow control and error correction in telecommunication networks.  |
                         sip  |
                     Allows SIP (Session Initiation Protocol) traffic through the firewall using its default ports. This option is disabled by default. |
                         tftp  |
                     Enables the TFTP (Trivial File Transfer Protocol) algorithm. When enabled, allows TFTP traffic through the firewall using its default ports. This option is enabled by default. |
nx9500-6C8809(config-fw-policy-testFW)#show context
         nx9500-6C8809(config-fw-policy-testFW)#show context firewall-policy testFW no ip dos tcp-sequence-past-window alg facetime nx9500-6C8809(config-fw-policy-testFW)#
| no | Removes or reverts ALG related settings |
