url-list
      Creates a URL list and enters its configuration mode. URL
         lists are a means of categorizing URLs on the basis of various criteria, such as frequently
         used, not-permitted, etc. It is used in URL filters to identify whitelisted/blacklisted
         URLs. Web requests are blocked or approved based on URL filter whitelist/blacklist rules. A
         whitelist bans all sites except the categories and URL lists defined in the whitelist. The
         blacklist allows all sites except the categories and URL lists defined in the
         blacklist.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         url-list <URL-LIST-NAME>
      Parameters
                     | <URL-LIST-NAME> |
                           - Specify the URL list
                              name. The URL list is created if another list with the same name does
                              not exist.
         nx9500-6C8809(config)#url-list URLlist1
nx9500-6C8809(config-url-list-URLlist1)#?
URL List Mode commands:
  description  Description of the category
  no           Negate a command or set its defaults
  url          Add a URL entry
  clrscr       Clears the display screen
  commit       Commit all changes made in this session
  do           Run commands from Exec mode
  end          End current mode and change to EXEC mode
  exit         End current mode and down to previous mode
  help         Description of the interactive help system
  revert       Revert changes
  service      Service Commands
  show         Show running system information
  write        Write running configuration to memory or terminal
         nx9500-6C8809(config-url-list-URLlist1)#url http://www.example_company.com depth 10
         nx9500-6C8809(config-url-list-test)#show context
url-list test
      Related Commands
                     | no |
                     Removes an existing URL list |
