https
Configures the HTTPS parameter type, attribute type, match criteria for
the HTTPS server name and 64 character maximum server name attribute used in the HTTPS
server message exchange
Supported on the following
platforms:
- Access Points — AP6522, AP6562,
AP7161, AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP763, AP7662,
AP8163, AP8543, AP8533
- Service Platforms —
- Virtual Platforms — CX9000,
Syntax
https server-cert common-name [contains|ends-with] <WORD>
Parameters
https server-cert |
Configures the HTTPS parameter type as server
certificate |
common-name [contains|ends-with] <WORD> |
Configures the HTTPS attribute match criteria as common
name. This is the only option applicable when the HTTPS parameter type is set to
server-cert. Use one of the following options to provide the common-name attribute
value used as the match criteria:
- contains – Filters applications having common-name attributes containing the
string specified here
- ends-with – Filters applications ending with the string specified here
- <WORD> – Specify the string to match (should not exceed 64
characters).
nx9500-6C8809(config-application-Bing)#https server-cert common-name exact bing.com
nx9500-6C8809(config-application-Bing)#show context
application Bing
description "Bing is Microsoft's web search engine"
app-category streaming
Related Commands
no |
Removes the HTTPS common-name attribute value configured
with this application category |
