auto-learn
Profile Config Commands
Enables controllers or service platforms to maintain a local configuration record of devices requesting adoption and provisioning. The command also enables learning of a device‘s host name via DHCP options.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
auto-learn [host-name-via-dhcp <WORD>|staging-config]
Parameters
| auto-learn
[host-name-via-dhcp <WORD>| staging-config] |
Enables
auto-learning of:
- host-name-via-dhcp – A
device‘s host name via DHCP option.
- <WORD> –
Provide the optional template with substitution token. For
example, 'outdoor-$DHCP[1:3]-ap', where the $DHCP token
references DHCP Option value received by the adopting device.
The $DHCP token should be present. This option is disabled by
default.
- staging-config – The
network configuration of devices requesting adoption. This option is
enabled by default. For dependent access points that are pre-staged
prior to deployment, it is recommended that the
auto-learn-staging-config parameter remains enabled so that hostnames,
VLAN and IP addressing configuration can be maintained upon initial
adoption. However, if dependent access points are to be centrally
managed and configured, it is recommended that the
auto-learn-staging-config parameter be disabled
nx9500-6C8809(config-profile-test)#auto-learn staging-config
nx9500-6C8809(config-profile-test)#show context include-factory | include auto-learn
no auto-learn host-name-via-dhcp
Related Commands
| no |
Disables automatic recognition of devices‘ hostname and devices pending adoption |
