The following table summarizes bridge VLAN configuration mode commands:
Command | Description |
bridging-mode | Configures how packets on this VLAN are bridged |
captive-portal | Enables IP packet snooping on wired captive portals, and also configures the subnet to snoop |
captive-portal-enforcement | Enables auto-enforcement of captive portal rules on this extended VLAN interface |
description | Configures VLAN bridge description |
edge-vlan | Enables edge VLAN mode |
firewall | Enables firewall on this bridge VLAN interface |
http-analyze | Enables the analysis of URLs and data traffic on this Bridge VLAN |
ip | Configures IP components |
ipv6 | Configures IPv6 components |
l2-tunnel-broadcast-optimization | Enables broadcast optimization |
l2-tunnel-forward-additional-packet-types | Enables forwarding of WNMP (Wireless Network Management Protocol) packets across L2 tunnels. These WNMP packets are normally not forwarded if L2 tunnel broadcast optimization is enabled. |
mac-auth | Enables MAC authentication for Extended VLAN and Tunneled traffic (both MiNT and L2TPv3) |
name | Configures a name for the selected Bridge VLAN |
no | Negates a command or reverts settings to their default |
stateful-packet-inspection-l2 | Enables stateful packet inspection in the layer 2 fire wall |
registration | Enables forwarding of bridge-vlan information (such as, name and vlan) to the ExtremeGuest (EGuest) server. |
tunnel | Enables tunneling of unicast messages to unknown MAC destinations, on the selected VLAN bridge |
tunnel-over-level2 | Enables extended VLAN traffic over level 2 MiNT links |
use | Associates a captive-portal, access control list (IP, IPv6, or MAC), and a URL filter with this bridge VLAN |
