unsuppress-map (bgp-neighbor-config)
    Un-suppresses map to selectively
      advertise routes that have been suppressed using the aggregate-address command. The
      aggregate-address command creates a route map with a IP/mask address that consolidates subnets
      under it. This reduces the number of route maps on the BGP device to one consolidated entry.
      Use unsuppress-map to selectively allow/deny a subnet or a set of subnets from this
      consolidated entry.
        - Service Platforms — NX9500, NX9600
    Syntax
      unsuppress-map <ROUTE-MAP-NAME>
    Parameters
              | unsuppress-map <ROUTE-MAP-NAME> |
              Un-suppresses the specified route map
                  - <ROUTE-MAP-NAME> – Specify the route map name.
      nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99# unsuppress-map test
      nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99#show context
  bgp neighbor 192.168.13.99
   remote-as 199
   maximum-prefix 9999 80 restart 50
   unsuppress-map test
