http-analyze
Enables HTTP URL analysis on the WLAN
Syntax
http-analyze [filter|syslog]
http-analyze filter [images|post|query-string]
http-analyze syslog host <IP/HOSTNAME> {port <1-65535>}
{proxy-mode [none|through-controller|through-rf-domain-manager]}
Parameters
filter Filters URLs, based on the parameters set, before forwarding them
images Filters out URLs referring to images (does not forward URL requesting images)
post Filters out URLs requesting POST (does not forward POST requests). This option is disabled by default.
query-string Removes query strings from URLs before forwarding them (forwards requests and no data). This option is disabled by default.
syslog host <IP/HOSTNAME> Forwards client and URL information to a syslog server
  • host <IP/HOSTNAME> – Specify the syslog server's IP address or hostname
port <1-65535> Optional. Specifies the UDP port to connect to the syslog server from 1 - 65535
proxy-mode [none|through-controller| through-rf-domain-manager] Optional. Specifies if the request is to be proxied through another device
  • none – Requests are sent directly to syslog server from device
  • through-controller – Proxies requests through the wireless controller configuring the device
  • through-rf-domain-manager – Proxies the requests through the local RF Domain manager
ap505-13403B(config-wlan-test)#http-analyze syslog host 10.234.160.4 port 21 proxy-mode
through-controller
ap505-13403B(config-wlan-test)#show context
wlan test
 ssid test
 vlan 1
 bridging-mode local
 encryption-type gcmp256
 authentication-type eap
 dynamic-vlan-assignment allowed-vlans 2-4
 protected-mgmt-frames mandatory
 protected-mgmt-frames sa-query attempts 1
 use aaa-policy test
 http-analyze syslog host 10.234.160.4 port 21 proxy-mode through-controller
 controller-assisted-mobility
 dpi metadata http
Related Commands
no (wlan-config-mode) Disables HTTP URL analysis on the WLAN
