Configures the mode used to select the server from a pool of AAA servers. The available methods are failover and load-balance.
In the failover scenario, when a configured AAA server goes down, the server with the next higher index takes over for the failed server.
In the load-balance scenario, when a configured AAA server goes down, the remaining servers distribute the load amongst themselves.
server-pooling-mode [failover|load-balance]
                         failover  |
                         Sets the pooling mode to failover. This is the default setting. When a configured AAA server fails, the server with the next higher index takes over the failed server's load.  |
                         load-balance  |
                         Sets the pooling mode to load balancing. When a configured AAA server fails, all servers in the pool share the failed server's load, transmitting requests in a round-robin fashion.  |
nx9500-6C8809(config-aaa-policy-test)#server-pooling-mode load-balance
         nx9500-6C8809(config-aaa-policy-test)#show context aaa-policy test authentication server 5 host 172.16.10.10 secret 0 test2 port 1 authentication server 5 timeout 10 attempts 3 accounting server 2 host 172.16.10.10 secret 0 test1 port 1 server-pooling-mode load-balance mac-address-format quad-dot case upper attributes username-password accounting server preference auth-server-number health-check interval 4000 nx9500-6C8809(config-aaa-policy-test)#
| no | Resets the method of selecting a server, from the pool of configured AAA servers |
