To enable mandatory statistics reporting for an application or set of applications, create an application group, add the desired application(s), and enable mandatory stats reporting for the group. Once enabled, the specified application(s) usage stats is always reported.
At any given time, only ten (10) applications can be reported to the NSight server. These are the top-ten applications, by usage, identified by the system. However, if mandatory application stats reporting is enabled, applications, within the specified application group, have to be included in the report. This is done by dropping some of the top-ten applications. For example, if mandatory application reporting is enabled for five (5) applications, the report will contain these 5 applications, plus first 5 of the top-ten applications identified by the system, totaling the number to ten.
mandatory app stats app-group <APPLICATION-GROUP-NAME>
mandatory app stats | Enables mandatory AVC statistics reporting for a specified application group |
app-group <APPLICATION-GROUP-NAME> | Specifies the application group for which statistics
reporting is to be made mandatory. When configured, usage statistics, for the
specified application group, is always reported to the NSight server.
Note: An application group can have a maximum of eight
(8) applications.
nx9500-6C8809(config-nsight-policy-test)#mandatory app stats app-group socialnetworking
nx9500-6C8809(config-nsight-policy-test)#show context nsight-policy test server host 1.2.3.4 https nx9500-6C8809(config-nsight-policy-test)#
Following is the "socialnetworking" application-group configuration. It contains three applications, which will be always reported to the NSight server even if they are not in the top-ten applications by usage list.
nx9500-6C8809(config-app-group-socialnetworking)#show context application-group socialnetworking application facetime application Facebook_chat application "Google Hangouts_audio" nx9500-6C8809(config-app-group-socialnetworking)#
no (nsight-policy-config-commands) | Disables mandatory application-usage statistics reporting |
