The following table summarizes captive portal configuration mode commands:
                         Command  |
                         Description  |
| access-time |
                         Defines a client's access time. It is used when no session time is defined in the RADIUS response.  |
| access-type |
                         Configures a captive portal's access type  |
| accounting |
                         Enables a captive portal's accounting records  |
| bypass |
                         Enables bypassing of captive portal detection requests  |
| connection-mode |
                         Configures a captive portal's connection mode  |
| custom-auth |
                         Configures custom user information  |
| data-limit |
                         Enforces data limit on captive portal clients  |
| frictionless-onboarding | Enables wireless clients, associated with guest WLANs, to self-register with the ExtremeGuest server. |
| inactivity-timeout |
                         Defines an inactivity timeout in seconds  |
| ipv6 | Configures the IPv6 address of the internal captive portal server |
| localization | Configures an FQDN address string that enables the client to receive localization parameters. This command also allows the configuration of a response message. |
| logout-fqdn |
                         Clears the logout FQDN address  |
| no |
                         Reverts the selected captive portal‘s settings or resets settings to default  |
| oauth | Enables OAuth-based authentication support on the captive portal. When enabled, OAuth allows captive-portal users to sign in to guest WLANs using their Facebook or Google credentials. |
| php-helper | Configures a PHP helper to serve the captive portal‘s PHP splash pages to guest users using social-media to login to the captive portal. |
| post-authentication-vlan |
                         Assigns a post authentication RADIUS VLAN for this captive portal‘s users  |
| radius-vlan-assignment |
                         Assigns a RADIUS VLAN for this captive portal  |
| redirection |
                         Enables redirection of client connections to specified destination ports  |
| report-royalty-application | Enables detection of captive portal client‘s loyalty application presence and stores this information in the captive portal‘s user database |
| server |
                         Configures the captive portal server settings  |
| simultaneous-users |
                         Specifies a username used by a MAC address pool  |
| terms-agreement |
                         Enforces the user to agree to terms and conditions (included in login page) for captive portal access  |
| use |
                         Associates a AAA policy and a DNS whitelist with a captive portal  |
| webpage |
                         Configures captive portal Web page settings  |
| webpage-auto-upload |
                         Enables automatic upload of advanced Web pages on a captive portal  |
| webpage-location |
                         Specifies the location of Web pages used for captive portal authentication  |
| welcome-back | Enables the provision of direct Internet access to once-registered, captive-portal guest users on subsequent log-ins |
| configuring-device-registration-with-dynamic-vlan-assignment | Provides the configuration details required to enable device registration with dynamic VLAN assignment in a multi-vendor environment. |
| configuring WeChat Wi-Fi hotspot support in WiNG captive portal | Provides configuration detals required to enable WeChat Wi-Fi hotspot support in WiNG captive portal. |
| configuring ExtremeGuest captive portal | Provides the basic configurations required to deploy an ExtremeGuest setup |
