The neighbor-recovery parameters can be modified only if the sensitivity level is set to ‘custom‘. For more information, see sensitivity.neighbor-recovery {dynamic-sampling|power-hold-time|power-threshold}
         neighbor-recovery {dynamic-sampling} {retries <1-10>|threshold <1-30>}
         neighbor-recovery {power-hold-time <0-3600>}
         neighbor-recovery {power-threshold [2.4Ghz|5Ghz|6Ghz] <-85--55>}
                         dynamic-sampling  |
                     Optional. Enables dynamic sampling on this Smart RF policy. Dynamic sampling allows you to define how Smart RF adjustments are triggered by locking the ‘retry‘ and ‘threshold‘ values. Dynamic sampling is disabled by default. |
                         retries <1-10>  |
                     Optional. Specifies the number of retries before
                        allowing a power level adjustments to compensate for a potential coverage
                           hole.
                         threshold <1-30>  |
                     Optional. Specifies the minimum number of sample
                        reports before which a power change requires dynamic sampling
                         power-hold-time  |
                     Optional. Specifies the minimum time, in seconds, between two power changes on a radio during neighbor-recovery |
                         <0-3600>  |
                     Sets the time from 0 - 3600 sec. The default is 0 seconds. |
                         power-threshold  |
                     Optional. Specifies the power threshold based on which recovery is
                           performed The 2.4 GHz/5.0/6.0 GHz radio uses the value specified here as the maximum power increase threshold if the radio is required to increase its output power to compensate for a failed radio within its coverage area.  |
                         [2.4GHz|5GHz|6GHz]  |
                         Selects the band
                         <-85--55>  |
                         Specify the threshold value
nx9500-6C8809(config-smart-rf-policy-test)#neighbor-recovery power-threshold 2.4GHz -82
         nx9500-6C8809(config-smart-rf-policy-test)#neighbor-recovery power-threshold 5GHz -65
         nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test group-by floor sensitivity custom assignable-power 2.4GHz max 20 assignable-power 2.4GHz min 8 channel-list 2.4GHz 1,12 channel-width 5GHz auto channel-width 2.4GHz auto area test channel-list 2.4GHz 1,2,3 avoidance-time dfs 300 interference-recovery channel-switch-delta 2.4GHz 5 neighbor-recovery power-threshold 5GHz -65 neighbor-recovery power-threshold 2.4GHz -82 coverage-hole-recovery snr-threshold 2.4GHz 35 nx9500-6C8809(config-smart-rf-policy-test)#
| no (smart-rf-policy-config-mode-command) |
                         Disables recovery from faulty neighbor radios  |
