Configures a wireless client filter based on the employee ID
employeeid [any|contains|exact|not-contains]
employeeid [any|exact <WORD>|contains <WORD>|not-contains <WORD>]
                         employeeid  |
                         Specifies a wireless client filter based on how the ‘employee ID‘, returned by the RADIUS server, matches the provided expression. Select one of the following options: any, contains, exact, or not-contains.  |
                         any  |
                         No specific employee ID associated with this user-defined role. This role can be applied to any wireless client having any employee ID (no strings to match). This is the default setting.  |
                         contains <WORD>  |
                         The role is applied only when the employee ID, returned by the RADIUS server, contains the string specified in the role.
                         exact <WORD>  |
                         The role is applied only when the employee ID, returned by the RADIUS server, exactly matches the string specified in the role.
                         not-contains <WORD>  |
                         The role is applied only when the employee ID, returned by the RADIUS server, does not contain the string specified in the role.
nx9500-6C8809(config-role-policy-test-user-role-testing)#employeeid contains TnVTest1
         nx9500-6C8809(config-role-policy-test-user-role-testing)#show context user-role testing precedence 10 authentication-type eq kerberos ap-location contains office captive-portal authentication-state pre-login city exact SanJose company exact ExampleCompany country exact America department exact TnV emailid exact testing@examplecompany.com employeeid contains TnVTest1 nx9500-6C8809(config-role-policy-test-user-role-testing)#
| no |
                         Removes the employee ID configured with this user-defined role  |
