BSS coloring impacts channel access behavior and spatial reuse operation. Based on the BSS color detected, APs can assign new channel access behavior. Spatial reuse, applies adaptive Clear Channel Assessment (CCA) thresholds for detected OBSS frame transmissions, enabling APs to ignore transmissions from an OBSS and therefore be able to transmit at the same time.
Use this command to configure support for 802.11ax BSS coloring and assign the BSS color associated with the radio. BSS color support is disabled by default.
11axBSScolor <1-63>
11axBSScolor | Configures support for 802.11ax BSS color |
<1-63> | Specify the BSS color identifier from 1 - 63. A maximum of 63 BSSs can be identified. |
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#11axBSScolor 20
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#show context interface radio1 11axSupport 11axBSScolor 20 ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#
no (radio-interface-config-command) | Disables BBS color identifier support on the selected radio |
