ldap-deadperiod
Configures LDAP dead period interval
Syntax
ldap-deadperiod <60-300>
Parameters
Configures an LDAP dead period. When enabled, LDAP service allows the AP or controller to bind with the LDAP server and retrieve user details to match with user-defined role filters. The LDAP deadperiod is the interval between two consecutive attempts to bind with the LDAP server. To enable LDAP service, use the ldap-query command.
  • <60-300> – Specify the interval from 60 - 600 seconds. The default is 120 seconds.
nx9500-6C8809(config-role-policy-test)#ldap-deadperiod 100
nx9500-6C8809(config-role-policy-test)#show context
role-policy test
 default-role use ip-access-list in test precedence 1
 ldap-deadperiod 100
Related Commands
no (role-policy-config-mode-command)
Removes or resets the LDAP deadperiod interval
