This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.telnet <IP/HOSTNAME> {<TCP-PORT>} {<INTF-NAME>}
<IP/HOSTNAME> | Configures the destination remote system‘s IP
(IPv4 or IPv6) address or hostname. The Telnet session is established
between the connecting system and the remote system.
<TCP-PORT> | Optional. Specify the Transmission Control Protocol (TCP) port number. |
<INTF-NAME> | Optional. Specify the interface name for the link local address. |
nx9500-6C8809#telnet 10.234.160.37 Entering character mode Escape character is '^]'. AP510 release 7.3.1.0-001D ap510-133B38 login:
