Configures BGP (Border Gateway Protocol) settings
BGP is an inter-ISP routing protocol which establishes routing between ISPs (Internet Service Providers). ISPs use BGP to exchange routing and reachability information between AS (Autonomous Systems) on the Internet. BGP makes routing decisions based on paths, network policies and/or rules configured by network administrators. The primary role of a BGP system is to exchange network reachability information with other BGP peers. This information includes information on AS that the reachability information traverses. This information is sufficient to create a graph of AS connectivity from which routing decisions can be created and rules enforced.
An AS is a set of routers under the same administration that use IGP (Interior Gateway Protocol) and common metrics to define how to route packets within the AS. AS uses inter-AS routing to route packets to other ASs. For an external AS, an AS appears to have a single coherent interior routing plan and presents a consistent picture of the destinations reachable through it.
Routing information exchanged through BGP supports only destination based forwarding (it assumes a router forwards packets based on the destination address carried in the IP header of the packet).
BGP uses TCP as its transport protocol. This eliminates the need to implement explicit update fragmentation, retransmission, acknowledgment, and sequencing. BGP listens on TCP port 179. The error notification mechanism used in BGP assumes that TCP supports a graceful close (all outstanding data is delivered before the connection is closed).
bgp [as-path-list|community-list|extcommunity-list|ip-access-list|ip-prefix-list] <LIST-NAME>
as-path-list <LIST-NAME> | Creates an AS path list and enters its configuration
mode
community-list <LIST-NAME> | Creates a community list and enters its configuration
mode
extcommunity-list <LIST-NAME> | Creates an extended community list and enters its
configuration mode
ip-access-list <LIST-NAME> | Creates a BGP IP access list and enters its
configuration mode
ip-prefix-list <LIST-NAME> | Creates a BGP IP prefix list and enters its
configuration mode
nx9500-6C8809(config)#bgp ? as-path-list BGP AS path list Configuration community-list Add a community list entry extcommunity-list Add a extended community list entry (EXPERIMENTAL) ip-access-list Add an access list entry ip-prefix-list Build a prefix list nx9500-6C8809(config)#
nx9500-6C8809(config)#bgp as-path-list AS-TEST-PATH nx9500-6C8809(config-bgp-as-path-list-AS-TEST-PATH)#? BGP AS Path List Mode commands: deny Specify packets to reject no Negate a command or set its defaults permit Specify packets to forward clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-bgp-as-path-list-AS-TEST-PATH)#
no | Modifies BGP settings, based on the parameters passed |
