application
Creates a new
application definition and enters its configuration mode. Use this command
to create a customized application detection definition.
The WiNG 7.1.X release
does not support DPI (application visibility) on AP5XX model access
points.
Supported on the following
platforms:
- Access Points — AP6522, AP6562,
AP7161, AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP763, AP7662,
AP8163, AP8543, AP8533
- Service Platforms —
- Virtual Platforms — CX9000,
Syntax
application <APPLICATION-NAME>
Parameters
application <APPLICATION-NAME> |
Creates a new application definition and enters its
configuration mode
- <APPLICATION-NAME> – Specify a name of the new application definition. It
is created if not already existing in the system.
nx9500-6C8809(config)#application Bing
nx9500-6C8809(config-application-Bing)#?
Application Mode commands:
app-category Set application category (default is custom)
description Add application description
https Secure HTTP
no Negate a command or set its defaults
use Set setting to use
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no |
Removes an existing application definition |
