Notational Conventions
The following notational conventions are used in this document:
Understanding Command Syntax
<variable> Variables are described with a short description enclosed within a ‘<‘ and a ‘>' pair.
For example, the command,
nx9500-6C8809>show interface ge 1
is documented as:
show interface ge <1-2>
where:
  • show – is the command – displays information
  • interface – is the keyword – represents the interface type
  • <1-2> – is the variable – represents the ge interface index value
    Note: Since this output is from an NX 9500 service platform, which supports only two (2) GE interfaces, the index value is shown as <1-2>. This value will vary depending on the platform type.
| The pipe symbol. This is used to separate the variables/keywords in a list.
nx9500-6C8809> show .....
is documented as:
show [adoption|bluetooth|bonjour|boot|...........
where:
  • [adoption|bluetooth|bonjour|boot|.........] – indicates the different keywords that can be combined with the show command. However, only one of the above option can be used at a time.
show adoption ...
show bluetooth ...
show bonjour ...
Of the different keywords and variables listed inside a ‘[‘ & ‘]' pair, only one can be used. Each choice in the list is separated with a ‘|' (pipe) symbol.
nx9500-6C8809# clear ...
is documented as:
clear [arp-cache|bonjour|cdp|counters|crypto|
event-history|firewall|gre|ip|ipv6|l2tpv3-stats|lacp|
license|lldp|logging|mac-addresstable|mint|role|rtls|
spanning-tree|traffic-shape|vrrp]
where:
  • clear – is the command
  • [arp-cache|bonjour|cdp|counters|crypto| ….….…....|vrrp] – indicates that these keywords are available for this command. However, only one can be used at a time.
{ } Any command/keyword/variable or a combination of them inside a ‘{‘ &‘}' pair is optional. All optional commands follow the same conventions as listed above. However, they are displayed italicized.
nx9500-6C8809> show adoption ....
is documented as:
show adoption info {on <DEVICE-NAME>}
here:
  • show adoption info – is the command. This command can also be used as:
show adoption info
The command can also be extended as:
here:
  • {on <DEVICE-NAME>} – is the optional keyword.
command / keyword The first word is always a command. Keywords are words that must be entered as is. Commands and keywords are mandatory.
nx9500-6C8809>show wireless
is documented as:
show wireless
where:
  • wireless – is the keyword
() Any command/keyword/variable or a combination of them inside a ‘(‘ & ‘)' pair are recursive. All recursive commands can be listed in any order and can be used once along with the rest of the commands.
crypto pki export request generate-rsa-key test autogen-subject-name ...
is documented as:
nx9500-6C8809#crypto pki export request generate-rsa-key test
autogen-subject-name (<URL>,email <EMAIL>,fqdn <FQDN>,ip-address <IP>)
here:
  • crypto pki export request generate-rsa-key <RSA-KEYPAIR-NAME> auto-gen-subject-name – is the command
  • <RSA-KEYPAIR-NAME> – is the RSA keypair name (in this example, the keypair name is ‘test')
  • (<URL>,email <EMAIL>,fqdn <FQDN>,ip-address <IP>) – is the set of recursive parameters (separated by commas) that can be used in any order.
