Configures a WIPS policy signature. A WIPS signature is the set of parameters or patterns used by WIPS to identify and categorize particular sets of attack behaviors in order to classify them. Use this option to configure signatures in the WIPS policy. The WIPS policy compares packets in the network with pre configured signatures to identify threats.
signature <SIGNATURE-NAME>
| signature <SIGNATURE-NAME> | Configures a WIPS policy signature
nx9500-6C8809(config-wips-policy-test)#signature test nx9500-6C8809(config-test-signature-test)#
nx9500-6C8809(config-test-signature-test)#? Wips Signature Mode commands: bssid Bssid mac address dst-mac Destination mac address filter-ageout Configure filter ageout frame-type Configure frame-type to match interference-event Signature is a smart-rf interference source mode Enable/Disable signature no Negate a command or set its defaults payload Configure a payload src-mac Source mac address ssid-match Match based on ssid threshold-client Configure client threshold limit threshold-radio Configure radio threshold limit clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-test-signature-test)#
| no (wips-policy-config-mode-command) | Deletes a WIPS policy signature |
