eddystone
         interface-config-bluetooth-instance
Configures Eddystone beacon payload parameters. Configure these parameters only if the Bluetooth radio interface‘s operational mode is set to ‘le-beacon‘, and the beacon‘s emitted transmission pattern is set to either ‘eddystone-url1‘ or ‘eddystone-ulr2‘.
            - Access Points –
               AP510, AP505, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432,
               AP8533
eddystone [calibration-rssi <-127-127>|url [1|2] <WORD>]Parameters
eddystone [calibration-rssi|url [1|2] <WORD>]
                        <-127-127>| url [1|2] <WORD>] | If the Beacon transmission pattern has been set to either ‘eddystone-url1‘ or ‘eddystone-url2‘, configure the following Eddystone parameters:
                           calibration-rssi – Configures the Eddystone beacon measured calibration signal strength, from -127 to 127 dBm, at 0 meters. Mobile devices can approximate their distance to beacons based on received signal strength. However, distance readings can fluctuate since they depend on several external factors. The closer you are to a beacon, the more accurate the reported distance. This setting is the projected calibration signal strength at 0 meters.
                                 <-127-127> – Specify a value from -127 - 127 dBm. The default value is -19 dBm.url [1|2] <WORD> – Configures the Eddystone URL as URL1 OR URL2
                                 1 – Selects the Eddystone URL number 12 – Selects the Eddystone URL number 2 The following keyword is common to the ‘eddystone-url1‘ and ‘eddystone-url2‘ keywrods:
                           <WORD> – Enter a 64 character maximum eddystone-URL1/eddystone-URL2. The URL must be 18 characters or less once auto-encoding is applied. URL  encoding is used when placing text in a query string to avoid confusion with the URL itself. It is typically used when a browser sends data to a Web server. |
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#eddystone calibration-rssi -120
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#show context
 interface bluetooth1
  shutdown
  description AP8432-BLE-Radio1
  mode le-beacon
  beacon pattern eddystone-url2
  beacon period 900
Related Commands
                     |  | Removes or reverts to default this Bluetooth radio‘s Eddystone beacon payload configurations |
