interface-config-radio-instance
Configures the selected radio‘s description that helps differentiate it from other radios with similar configurations
description <WORD>
description <WORD>
| description <WORD> | Provide a description for the selected radio (should not exceed 64 characters in length). |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#description "Primary radio to use" nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 description "Primary radio to use" channel 1 data-rates b-only beacon period 50 beacon dtim-period bss 1 5 beacon dtim-period bss 2 2 beacon dtim-period bss 3 5 beacon dtim-period bss 4 5 beacon dtim-period bss 5 5 beacon dtim-period bss 6 5 beacon dtim-period bss 7 5 beacon dtim-period bss 8 5 beacon dtim-period bss 9 5 beacon dtim-period bss 10 5 beacon dtim-period bss 11 5 beacon dtim-period bss 12 5 beacon dtim-period bss 13 5 beacon dtim-period bss 14 5 beacon dtim-period bss 15 5 beacon dtim-period bss 16 5 antenna-gain 12.0 aggregation ampdu tx-only --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Removes a radio‘s description |
