The environmental senor is supported only on an AP 8132. When executed on any controller (other than an AP 8132), the show > environmental-sensor > <parameters> command displays environmental-sensor details for adopted AP 8132s (if any).show environmental-sensor [history|humidity|light|motion|summary|temperature| version]
show environmental-sensor history {<1-HOUR>|<20-MINUTE>|<24-HOUR>}
         show environmental-sensor [humidity|light|motion|summary|temperature|version]
         | environmental-sensor history | Displays environmental sensor history once in every hour, 20 minutes, or
                        24 hours History includes the humidity, light, motion, and temperature data recorded by the sensor at specified time interval. |
| 1 hour | Optional. Displays environmental sensor history once in every 1 (one) hour |
| 20-minute | Optional. Displays environmental sensor history once in every 20 minutes |
| 24-hour | Optional. Displays environmental sensor history once in every 24 hours |
| environmental-sensor | Displays environmental sensor‘s recorded data, based on the parameters
                        passed. The system displays the specified recorded data. The environmental sensor records data at the following intervals: 20 minutes, 1 hour, and 24 hours |
| humidity | Displays the minimum, average, and maximum humidity recorded |
| light | Displays the minimum, average, and maximum light recorded |
| motion | Displays the minimum, average, and maximum motion recorded |
| temperature | Displays the minimum, average, and maximum temperature recorded |
| version | Displays the hardware and firmware versions |
| summary | Displays a summary of the data recorded at following intervals: |
ap8132-711728#show environmental-sensor summary
Maat Device uptime: 0 days 15:25:11
ERROR: Maat device is offline!
threshold polling-interval: 5
historical data polled 0 times per 2-minutes interval since Maat online
motion-sensor: Enabled(Demo)
  current value: 0 detected
                motion detected
  20-minute           0
  1-hour              0
  6-hour              0
  24-hour             0
temperature-sensor: Enabled(Demo)
  current value: -40.00 deg. C
                min/average/max
  20-minute         0/0/0
  1-hour            0/0/0
  6-hour            0/0/0
  24-hour           0/0/0
light-sensor: Enabled
  threshold-high:+400.00 threshold-low:+200.00 holdtime:11
  action radio-shutdown: radio-1 and radio-2
  light-on:1
  light-on/off event sent:0/0
  current value: 0.00 lux
                min/average/max
  20-minute         0/0/0
  1-hour            0/0/0
  6-hour            0/0/0
  24-hour           0/0/0
humidity-sensor: Enabled(Demo)
  current value: 0.00 %
                min/average/max
  20-minute         0/0/0
  1-hour            0/0/0
  6-hour            0/0/0
  24-hour           0/0/0
ap8132-711728#
         ap8132-711634#show env-sensor history
Current Time: 2015-06-20 14:08:01 UTC
     Sample-Interval          Motion    Temperature     Light       Humidity
                                          (deg. C)      (lux)         (%)
                                       ----------- min/average/max ------------
20-minute                       1         64/65/66      77/80        58/60/61
1-hour                          24        63/67/70      75/81        57/59/61
6-hour                          128       60/62/69      71/79        52/56/71
24-hour                         188       54/58/70      15/45        49/57/73
ap8132-711634#
         ap8132-711634#show env-sensor history 20-min --------------------------------------------------------------------------------- timestamp Motion Temperature Light Humidity --------------------------------------------------------------------------------- 2015-11-20 13:51:35 UTC 0 66 79 59 2015-11-20 13:53:35 UTC 0 66 79 59 2015-11-20 13:55:35 UTC 0 65 79 58 2015-11-20 13:57:35 UTC 1 66 80 59 2015-11-20 13:59:35 UTC 0 66 79 59 2015-11-20 14:02:35 UTC 0 65 79 60 2015-11-20 14:03:35 UTC 0 64 79 60 2015-11-20 14:05:35 UTC 2 66 80 60 2015-11-20 14:07:35 UTC 0 66 80 61 2015-11-20 14:09:35 UTC 0 66 80 61 ap8132-711634#
ap8132-711634#show env-sensor history 1-hr ---------------------------------------------------------------------------------- timestamp Motion Temperature Light Humidity ---------------------------------------------------------------------------------- 2015-11-20 13:51:35 UTC 0 66 79 59 2015-11-20 13:53:35 UTC 0 66 79 59 2015-11-20 13:55:35 UTC 0 65 79 58 2015-11-20 13:57:35 UTC 1 66 80 59 2015-11-20 13:59:35 UTC 0 66 79 59 2015-11-20 14:01:35 UTC 0 65 79 60 2015-11-20 14:03:35 UTC 0 64 79 60 2015-11-20 14:05:35 UTC 2 66 80 60 2015-11-20 14:07:35 UTC 0 66 80 61 2015-11-20 14:09:35 UTC 0 66 80 61 2015-11-20 14:42:35 UTC 0 65 81 60 2015-11-20 14:43:35 UTC 0 64 80 59 2015-11-20 14:45:35 UTC 3 66 80 60 ap8132-711634#
<DEVICE-NAME>#show env-sensor history 24-hr ---------------------------------------------------------------------------------- timestamp Motion Temperature Light Humidity ---------------------------------------------------------------------------------- 2015-11-20 10:10:20 UTC 27 66 80 60 2015-11-20 10:30:20 UTC 17 66 80 60 2015-11-20 10:50:20 UTC 17 66 81 60 2015-11-20 11:10:20 UTC 25 66 81 60 2015-11-20 11:30:20 UTC 24 66 81 60 2015-11-20 11:50:20 UTC 26 66 81 60 2015-11-21 08:10:20 UTC 9 65 80 59 2015-11-21 08:30:20 UTC 7 65 80 59 2015-11-21 08:50:20 UTC 12 65 80 60 2015-11-21 09:10:20 UTC 10 65 80 60 2015-11-21 09:30:20 UTC 15 65 80 60 2015-11-21 09:50:20 UTC 19 66 80 60 <DEVICE-NAME>#
