ip
crypto-map-ipsec-isakmp-instance
Enables this setting to utilize IP/Port NAT on this auto site-to-site VPN tunnel. This option is disabled by default.
Syntax
ip nat crypto
Parameters
ip nat crypto
ip nat crypto Enables this setting to utilize IP/Port NAT on the site-to-site VPN tunnel. This setting is disabled by default.
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#ip nat crypto
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#show context
 crypto map test 1 ipsec-isakmp
  ip nat crypto
