crypto-map-ipsec-isakmp-instance
Configures the remote VPN client type as either None or XAuth
remote-type [none|xauth]
remote-type [none|xauth] | Specify the
remote VPN‘s client type
XAuth (extended authentication) provides additional authentication validation by permitting an edge device to request extended authentication information from an IPSec host. This forces the host to respond with additional authentication credentials. The edge device respond with a failed or passed message. |
Remote VPN client: nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#remote-type none nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#show context crypto map test 2 ipsec-isakmp dynamic peer 1 ikev1 RemoteIKEv1Peer1 local-endpoint-ip 157.235.204.62 pfs 14 remote-type none nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#
