peer
crypto-map-ipsec-isakmp-instance
Configures the IKEv1 or IKEv2 peer for the auto site-to-site VPN tunnel or remote VPN client. The peer device can be specified either by its hostname or by its IP address. A maximum of three peers can be configured.
Syntax
peer <1-3> [ikev1|ikev2] <IKEv1/IKEv2-PEER-NAME>
Parameters
peer <1-3> Creates a new peer and configures the peer‘s priority level. Peer ‘1‘ is the primary peer, and peer ‘3‘ is redundant.
ikev1 <IKEv1-PEER-NAME> Configures an IKEv1 peer
  • <IKEv1-PEER-NAME> – Specify the IKEv1 peer‘s name.
ikev2<IKEv2-PEER-NAME> Configures an IKEv2 peer
  • <IKEv2-PEER-NAME> – Specify the IKEv2 peer‘s name.
Site-to-site tunnel:
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#peer 1 ikev2 ikev2Peer1
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#1)#show context
 crypto map test 1 ipsec-isakmp
  local-endpoint-ip 192.168.13.10
  ip nat crypto
Remote VPN client:
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#peer 1 ikev1 RemoteIKEv1Peer1
nx9500-6C8809(config-device-B4-C7-99-6C-88-09-cryptomap-test#2)#show context
 crypto map test 2 ipsec-isakmp dynamic
  local-endpoint-ip 157.235.204.62
