no
crypto-map-ipsec-manual-instance
Removes or resets this crypto map‘s settings
Syntax
no [local-endpoint-ip|mode|peer|security-association|session-key|use]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes or resets this crypto map settings based on the parameters passed
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#show context
 crypto map map1 1 ipsec-manual
  use ip-access-list test
  peer 172.16.10.12
  mode transport
  session-key inbound esp 273 0 cipher esp-null authenticator sha 5876897
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#no use ip-access-list
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#no peer
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#no mode
  session-key inbound esp 273 0 cipher esp-null authenticator sha 58768979
