police [flow|srtcm-color-aware|srtcm-color-blind|trtcm-color-aware|trtcm-color-blind]
police flow <0-1000000> <0-16000000> conform-action transmit violate-action [<0-63>|drop]
police [srtcm-color-aware|srtcm-color-blind] <0-1000000> <0-16000000> <0-16000000> conform-action transmit exceed-action [<0-63>|drop] violate-action [<0-63>|drop]
police [trtcm-color-aware|trtcm-color-blind] <0-1000000> <0-16000000> <0-1000000> <0-16000000> conform-action transmit exceed-action [<0-63>|drop] violate-action [<0-63>|drop]
| police | Configures an enforcer for classified traffic |
| flow <0-1000000> <0-16000000> | Configures an enforcer for classified traffic based on
                the metered flow rate
 Policing is based on a token bucket, where bucket depth (i.e., the maximum burst before the bucket overflows) is specified by the committed-burst field, and the average rate tokens are added to the bucket is specified by the committed-rate option. Note, the token bucket functions similar to that described in RFC 2697 and RFC 2698. The behavior of the meter is specified in terms of one token bucket (C), the rate at which the tokens are incremented CIR and the maximum size of the token bucket BC. The token bucket C is initially full, that is, the token count Tc(0) = BC. Thereafter, the token count Tc is updated CIR times per second as follows:The token bucket C is initially full, that is, the token count Tc(0) = BC. Thereafter, the token count Tc is updated CIR times per second as follows:  |
| conform-action transmit | Configures the action applied when packets fall within
                the specified CIR and BC limits
| violate-action [<0-63>|drop] | Configures the action applied when packets violate the
| [srtcm-color-aware| srtcm-color-blind] <0-1000000> <0-16000000> <0-16000000> | Configures an enforcer for classified traffic based on single rate three color
                meter (srTCM) mode. The srTCM as defined in RFC 2697 meters a traffic stream and
                processes its packets according to three traffic parameters – CIR, BC, and BE
                  (Excess Burst Size).
 The meter operates in one of two modes. In the color-blind mode, the meter
                  assumes that the packet stream is uncolored. In color-aware mode the meter assumes
                  that some preceding entity has pre-colored the incoming packet stream so that each
                  packet is either green, yellow, or red. The marker (re)colors an IP packet
                  according to the results of the meter. The color is coded in the DS field [RFC
                  2474] of the packet.
 The behavior of the meter is specified in terms of its mode and two token buckets, C and E, which both share the common rate CIR. The maximum size of the token bucket C is BC and the maximum size of the token bucket E is BE. The token buckets C and E are initially full, that is, the token count
                  Tc(0) = BC and the token count Te(0) = BE. Thereafter, the token counts Tc and Te
                  are updated CIR times per second as follows:
 When a packet of size B bytes arrives at time t, the following happens
                  if srTCM is configured to operate in color-blind mode:
                  if srTCM is configured to operate in color-aware mode:
 The metering policy guarantees a deterministic behavior where the volume of green packets is never smaller than what has been determined by the CIR and BC, that is, tokens of a given color are always spent on packets of that color. Refer to RFC 2697 for more information on other aspects of srTCM.  |
| conform-action transmit | Configures the action applied when packet rates fall
                within the specified CIR and BC limits
| exceed-action [<0-63>|drop] | Configures the action applied when packet rates exceed
| violate-action [<0-63>|drop] | Configures the action applied when packet rates exceed
                the specified BE limit
| [trtcm-color-aware| trtcm-color-blind] <0-1000000> <0-16000000> <0-1000000> <0-16000000> | Configures an enforcer for classified traffic based on a two rate three color
                meter (trTCM) mode. The trTCM as defined in RFC 2698 meters a traffic stream and
                processes its packets based on two rates – CIR and Peak Information Rate
                (PIR), and their associated burst sizes - BC and BP (Peak Burst Size).
 The meter operates in one of two modes. In the color-blind mode, the meter assumes that the packet stream is uncolored. In color-aware mode the meter assumes that some preceding entity has pre-colored the incoming packet stream so that each packet is either green, yellow, or red. The marker (re)colors an IP packet according to the results of the meter. The color is coded in the DS field [RFC 2474] of the packet. The behavior of the meter is specified in terms of its mode and two token buckets, P and C, which are based on the rates PIR and CIR, respectively. The maximum size of the token bucket P is BP and the maximum size of the token bucket C is BC. The token buckets P and C are initially (at time 0) full, that is, the token count Tp(0) = BP and the token count Tc(0) = BC. Thereafter, the token count Tp is incremented by one PIR times per second up to BP and the token count Tc is incremented by one CIR times per second up to BC. When a packet of size B bytes arrives at time t, the following happens
                  if trTCM is configured to operate in color-blind mode:
                  if trTCM is configured to operate in color-aware mode:
 The trTCM can be used to mark a IP packet stream in a service, where different, decreasing levels of assurances (either absolute or relative) are given to packets which are green, yellow, or red. Refer to RFC 2698 for more information on other aspects of trTCM.  |
                within the specified CIR and BP limits
                the specified CIR limit, but are within the specified PIR limit
The following example uses the police > trtcm-color-blind command to limit the average bandwidth to 100,000 Kbps, the committed burst rate to 4000 bytes, the peak information rate to 1,000,000 Kbps, the peak burst size to 6000, to remark any packets exceeding the committed burst size, and to drop any packets exceeding the peak information rate.
nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap-pmap-class-dscp)#police
 trtcm-color-blind 100000 4000 100000 6000 conform-action transmit exceed-action 0 violate-action drop
      nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap-pmap-class-dscp)#show context class dscp police trtcm-color-blind 100000 4000 100000 6000 conform-action transmit exceed-action 0 violate-action drop nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap-pmap-class-dscp)#
| no (ex3500-traffic-class-config-commands) | Removes the traffic enforcer settings |
