security-association
crypto-map-ipsec-manual-instance
Defines the lifetime (in kilobytes and/or seconds) of IPSec SAs created by this crypto map
Syntax
security-association lifetime [kilobytes <500-2147483646>|seconds <120-86400>]
Parameters
lifetime [kilobytes <500-2147483646>| seconds <120-86400>] Values can be entered in both kilobytes and seconds. Which ever limit is reached first, ends the security association.
  • kilobytes <500-2147483646> – Defines volume based key duration. Specify a value from 500 - 2147483646 bytes.
  • seconds <120-86400> – Defines time based key duration. Specify the time frame from 120 - 86400 seconds.
This command is not applicable to the ipsec-manual crypto map.
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map2#2)#security-association lifetime seconds 123
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map2#2)#show context
 Command not applicable to this crypto map
