peer
crypto-map-ipsec-manual-instance
Sets the peer device‘s IP address. This can be set for multiple remote peers. The remote peer can be an IP address.
Syntax
peer <IP>
Parameters
peer <IP>
peer <IP> Enter the peer device‘s IP address. If not configured, it implies respond to any peer.
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#peer 172.16.10.12
nx9500-6C8809(config-profile-default-ap8533-cryptomap-map1#1)#show context
 crypto map map1 1 ipsec-manual
  peer 172.16.10.12
