Use this command to set the number of seconds an ARP entry will remain in the stale state before the entry is removed from the ARP table.
seconds | Specifies the time in seconds that a stale entry remains in the ARP cache. Valid values are 1 - 65535. Default value: 1200 seconds. |
None.
Configuration command mode.
The “no” form of this command restores the default value of 1200 seconds.
This example shows how to set the ARP stale-entry-timeout to 900 seconds:
System(rw-config)->arp stale-entry-timeout 900
