Use this command to reset the resource limit for the specified application and VRF to the global value.
| vrf vrf-name | Specifies the name of the VRF to which the resource limit applies. |
| resource-ipv6netmask | Specifies the IPv6 netmask resource limit. |
| application | Specifies the application to which the resource limit applies. |
None.
All command modes.
Use the clear limits command to reset the resource limit, for the specified application, to its global limit or that the IPv6 netmask should be reset to the default value. Use the show limits command, specifying the application, to display an application‘s global limit, or specifying resource-ipv6netmask to display the current IPv6 netmask setting.
This example resets the OSPF link state entries resource limit on VRF vr2 to the global limit
System(su)->clear limits vrf vr2 application ospf-ls-entries System(su)->
Print
this page
Email this topic
Feedback
