Use this command to display global IPv4 SLB information.
None.
None.
All command modes.
This example shows how to display IPv4 server load balancing information:
System(rw)->show ip slb info Object System Max Avail VRF Used -------------------------------------------------- Virtual-IPs 1000 996 4 Reals 800 790 10 Sfarms 400 398 2 Vservers 500 496 4 FTP Control Port: 21 TFTP Control Port: 69 FIN/RST Timeout: Disabled Real-Server Access: Restricted Real-Server Access Tcp Reset: Disabled Real-Server Access Acl: Not Set TCP Half-Close uses FIN/RST Timeout: Disabled System(rw)->
Print
this page
Email this topic
Feedback
