Use this command to clear one or all Class of Service transmit queue port resource entry.
| all | group-type-index | Clears all transmit queue port resource entries or a specific entry. Valid group-type entries are in the form of group.type. Group can be 0 - 11, with 0 designating the default group, and 1 - 11 reserved for user-defined groups. Port type can be 0 - 1 for the S- and K-Series and 0 for the 7100-Series. |
| resource | Specifies a single or range resource entries to be cleared. |
| unit | (Optional) Clears unit of measure settings. |
| rate | (Optional) Clears rate settings. |
| algorithm | (Optional) Clears the taildrop algorithm setting. |
If no options are specified, all associated non-default settings will be cleared.
All command modes.
This S- and K-Series example shows how to clear all port resource settings associated with Class of Service transmit queue 1 in port group 0.1:
System(rw)->clear cos port-resource txq 0.1 1
This 7100-Series example shows how to clear all port resource settings associated with Class of Service transmit queue 1 in port group 0.0:
System(rw)->clear cos port-resource txq 0.0 1
Print
this page
Email this topic
Feedback
