Use this command to set the ECM (Equal Cost Multipath) forwarding algorithm used for forwarding IP packets on routing interfaces.
hash-thold | (Optional) Sets the ECM forwarding algorithm as hash threshold. |
round-robin | (Optional) Sets the ECM forwarding algorithm as round robin. |
If an algorithm is not specified, hash threshold will be set.
Configuration command, Global configuration.
The “no” form of this command removes the round-robin algorithm, resetting the algorithm to hash threshold.
This example shows how to set the round-robin ECM mode:
System(rw-config)->ip ecm-forwarding-algo round-robin
This example shows how to reset the ECM mode to the default forwarding algorithm of hash threshold:
System(rw-config)->no ip ecm-forwarding-algo
