Use this command to set a route metric to be used for redistribution by the source packet matched in this route-map.
| cost | Specifies a route cost to be used for redistribution by the source packet matched in this route-map. Valid values: 1 - 4294967295. Default Value: None. |
None.
Route-map configuration.
The “no” form of this command deletes this route metric set clause.
This example shows how to set the route cost to 200 for redistribution by the source packet matched in the rm5 route-map:
System(rw-config)->route-map redistribution rm5 System(rw-config-route-map)->set metric 200 System(rw-config-route-map)->
Print
this page
Email this topic
Feedback
