Configures a VRID state interface down to interface up transition delay period.
| vrid | Specifies the VRRP instance for this delay setting. |
| seconds | Specifies the number of seconds to set for the transition delay from VRID state interface down to interface up. Valid Values: 0 - 900. Default Value: 0. |
None.
Interface configuration mode.
The interface-up-delay is typically used to delay startup of the VRRP state machines while other protocols are transitioning. For example, you may want to prevent the VRRP state machines from processing a VRRP packet on the network while ports on that interface have not fully transitioned to forwarding from the STP protocol. By setting the interface-up-delay, the user can configure VRRP to start its protocol state machines after the STP protocol has had a chance to transition all forwarding packets.
The “no” form of this command sets the interface-up delay to the default value of 0 seconds.
This example sets the interface-up-delay for VRID 1 on interface VLAN 20 to 10 seconds:
System(rw)-> System(rw)->configure System(rw-config)->interface vlan 20 System(rw)-config-intf-vlan.0.20)->vrrp interface-up-delay 1 10 System(rw)-config-intf-vlan.0.20)->
Print
this page
Email this topic
Feedback
