Use this command to configure the TLV metric style for this IS-IS instance.
| wide | Specifies the wide TLV metric style. |
| both | Specifies both the wide TLV metric style and the narrow metric style (Default). |
None.
IS-IS router configuration.
The “no” form of this command resets the TLV metric style used for this routing instance to the default value of both wide and narrow TLV metric styles.
This example shows how to configure the IS-IS metric style to wide only:
System(rw)->configure System(rw-config)->router isis System(rw-config-isis)->metric-style wide System(rw-config-isis)->
Print
this page
Email this topic
Feedback
