Use this command to clear the statistics counters for one or all MSDP peers.
| peer-address | (Optional) Specifies the IP address of the MSDP peer for which the statistics counters are to be cleared. |
If no peer is specified, the statistics counters of all MSDP peers are cleared.
Global configuration mode.
If this command is run without the peer-address parameter, the statistics counters of all MSDP peers are cleared.
This example shows how to clear the statistics of MSDP peer 192.168.30.20:
System(su-config)->clear ip msdp peer statistics 192.168.30.20
Print
this page
Email this topic
Feedback
