Use this command to reset the device without losing any user-defined configuration settings.
None. You must enter one of the specified parameters.
All command modes.
An S- K- and 7100-Series module or the Standalone chassis can also be reset with the RESET button located on its front panel. For information on how to do this, refer to the Hardware Installation Guide shipped with your device.
If a reset command is issued while an S- or 7100-Series HA upgrade is pending, the HAU process will start.
This example shows how to reset the system.
System(rw)->reset system This command will reset the system and may disconnect your telnet session. Do you want to continue (y/n) [n]? y Resetting...
This example shows how to cancel a scheduled system reset:
System(rw)->reset cancel Reset cancelled.
Print
this page
Email this topic
Feedback
