Use this command to configure the metric associated with a set of destinations for DVMRP reports.
| metric | Specifies a metric associated with a set of destinations for DVMRP reports. Valid values are from 1 – 31. The default value is 1. |
None.
Configuration command, interface configuration.
Use the “no” version of this command to reset the DVMRP metric to the default value of 1.
This example shows how to set a DVMRP of 16 on VLAN 1:
System(rw-config-intf-vlan.0.1)->ip dvmrp metric 16
Print
this page
Email this topic
Feedback
