clear neighbors warning-detection
Use this command to reset a warning detection warning type to the default setting for all or specified ports.
Syntax
clear neighbors [port-string] warning-detection warning-type
Parameters
| port-string |
(Optional) disables neighbor warning detection on the
specified or range of ports. For a detailed description of possible
port-string values, refer to the S-, K-, and 7100 Series Configuration Guide. |
| warning-type |
The following warning types are supported:
- ciscodp-duplex – Detect neighbor differences in duplex
- ciscodp-max-frame – Detect neighbor differences in MTU
- lldp-v2-mac-phy – Detect neighbor differences in speed and duplex
- lldp-v2-power-via-mdi – Detect neighbor differences in power class
- lldp-v2-max-frame – Detect neighbor differences in MTU
- lldp-v2-lacp – Detect neighbor differences in LACP status
- lldp-v2-pfc – Detect neighbor differences in PFC status
Defaults
- If port-string is not specified, neighbor warning detection is reset to the default value on all ports for the specified warning type.
- ciscodp-duplex defaults to disabled.
- ciscodp-max-frame defaults to disabled.
- lldp-v2-mac-phy defaults to enabled.
- lldp-v2-power-via-mdi defaults to enabled.
- lldp-v2-max-frame defaults to enabled
- lldp-v2-lacp defaults to disabled.
- lldp-v2-pfc defaults to disabled.
This example shows how to disable the detect neighbor differences in MTU warning type on all ports:
System(rw)->set neighbor warning-detection lldp-v2-max-frame
