Use this command to reset the frame discard mode to the factory default setting (none).
| port-string | Specifies the port(s) for which to reset frame discard mode. For a detailed description of possible port-string values, refer to the S-, K-, and 7100 Series Configuration Guide. |
None.
All command modes.
This example shows how to reset port 7 to the default discard mode of “none”:
System(rw)->clear port discard ge.2.7
Print
this page
Email this topic
Feedback
