Use this command to display Class of Service units of measure information, including rate type, minimum and maximum limits of the port groups, and their respective granularity.
| irl | txq | flood-ctrl | (Optional) Displays inbound rate limiting, transmit queue,, or flood control information. |
| port-type index | (Optional) Displays information for a specific port type. Valid values are 0 - 1 for S- and K-Series and 0 for the 7100-Series. Default: All port-types. |
If not specified, all rate limiting information for all port types and CoS units of measure will be displayed.
All command modes.
This example shows how to show all CoS unit of measure information:
S- and K-Series
System(rw)->show cos unit
Type: Unit:
txq = transmit queue perc = percentage
irl = inbound rate limiting pps = packets per second
orl = outbound rate limiting Kbps = Kilobits per second
fld = flood rate limiting Mbps = Megabits per second
Gbps = Gigabits per second
Tbps = Terabits per second
Port Type Type Unit Maximum Rate Minimum Rate Granularity
0 txq Gbps 10 1 1
0 txq Mbps 10000 1 1
0 txq Kbps 10000000 64 1
0 txq perc 100 1 1
1 txq Gbps 10 1 1
1 txq Mbps 10000 1 1
1 txq Kbps 10000000 64 1
1 txq perc 100 1 1
0 irl Gbps 10 1 1
0 irl Mbps 10000 1 1
0 irl Kbps 10000000 8 1
0 irl pps 10000 1 1
0 irl perc 100 1 1
1 irl Gbps 10 1 1
1 irl Mbps 10000 1 1
1 irl Kbps 10000000 8 1
1 irl pps 10000 1 1
1 irl perc 100 1 1
0 orl Gbps 10 1 1
0 orl Mbps 10000 1 1
0 orl Kbps 10000000 8 1
0 orl pps 10000 1 1
0 orl perc 100 1 1
1 orl Gbps 10 1 1
1 orl Mbps 10000 1 1
1 orl Kbps 10000000 8 1
1 orl pps 10000 1 1
1 orl perc 100 1 1
0 fld Gbps 1 1 1
0 fld Mbps 1000 1 1
0 fld Kbps 100000 8 1
0 fld pps 10000 1 1
0 fld perc 100 1 1
7100-Series
Type: Unit:
0 txq Gbps 10 1 1
0 txq perc 100 1 1
0 irl Gbps 10 1 1
0 irl pps 10000 1 1
0 irl perc 100 1 1
0 fld pps 10000000 1 1
Print
this page
Email this topic
Feedback
