Use this command to create an UDP timing probe and enter probe timing configuration mode.
| probe-name | Specifies a UDP timing probe name. Valid values are up to 31 characters. The space character is not supported. |
None.
Global configuration.
The UDP timing probe allows you to collect timing information for UDP echo requests. After you execute this command, you enter probe timing configuration mode where you can further configure the probe.
The no form of the command deletes the probe from the Tracked Object Manager.
This example creates the UDP timing probe named UDP_STATS and enters probe timing configuration mode.
System(su)->configure System(su-config)->probe UDP_STATS udp timing System(su-config-probe-timing)->
Print
this page
Email this topic
Feedback
