Use this command to reset the OSPF process.
| process-id | (Optional) Specifies the process ID, an internally used identification number for each instance of the OSPF routing process run on a router. Valid values are 1 to 65535. |
If the process-id is not specified, the OSPF process is reset.
All command modes.
This command will require adjacencies to be reestablished and routes to be reconverged.
This example shows how to reset OSPF process 1:
System(rw)->clear ip ospf process 1
Print
this page
Email this topic
Feedback
