Use this command to assign a flow limiting user classification to one or more port(s)
| class-index | Specifies a numeric value or classification type keyword for the class user classification type to assign to this action. Valid values are from 0 - 4294967295 or a classification type keyword:
| port-string | (Optional) Specifies port(s) on which to configure flow limiting class. |
If port-string is not specified, the specified class setting will apply to all ports.
All command modes.
A maximum of 10 user classification types can be defined per port as a combination of numeric values and predefined user classification types. Once a classification is assigned, these ports will be subject to the flow limit configured (with the set flowlimit limit command as described in set flowlimit limit) and the action configured (with the set flowlimit action command as described in set flowlimit action).
Entering a predefined user classification type sets the numeric class index value to the value specified in the parameter table.
This example shows how to assign the user port classification type to ports ge.2.3-5:
System(rw)->set flowlimit port class userport ge.2.3-5
Print
this page
Email this topic
Feedback
