Use this command to reset the action thresholds in number of consecutive errored sample intervals before a transmit queue monitoring triggers the action to default values.
| disableport | (Optional) Specifies the threshold for disabling the port action will be reset to the default value. The default value is 10 consecutive errored sample intervals. |
| ignorepause | (Optional) Specifies the threshold for the ignore pause frame action will be reset to the default value. The default value is 5 consecutive errored sample intervals. |
| logging | (Optional) Specifies the threshold for the logging action will be reset to the default value. The default value is 2 consecutive errored sample intervals. |
If no options is specified, all thresholds are cleared.
All command modes.
This example shows how to reset the ignore pause frames action threshold to the default value of 5 sample intervals:
System(rw)->clear txqmonitor threshold ignorepause System(rw)->
Print
this page
Email this topic
Feedback
