Use this command to clear congestion notification configuration for the specified priority and context.
| priority | Specifies the CNPV to be cleared for the specified context. |
| entry | Deletes a congestion notification priority table entry for the specified CNPV. |
| status | Resets the status to the default value to enabled for the specified CNPV. |
| choice | Resets the domain defense choice to the default of auto. |
| alt-pri | Resets the alternate priority for the specified CNPV to the default of next lowest non-CNPV priority value or next highest non-CNPV value if all lower values are CNPV, if global defense choice is set to auto. If global defense choice is set to admin, the alternate priority defaults to 0. |
| defense | Resets the domain defense method for the specified CNPV to the default value of:
| creation | Resets the CNPV auto creation for all ports to the default value of enabled. |
| lldp | Resets the congestion notification LLDP state to the default value of enabled. |
None.
All command modes.
This example deletes congestion notification entry CNPV 3:
System(rw)->clear dcb cn priority 3 entry
Print
this page
Email this topic
Feedback
