Use this command to reset the PoE management mode on a specified module back to the default setting of “realtime”.
| module-number | Specifies the module on which to reset the PoE management mode. If you are clearing the management value on an S-Series, use 1 as the module number. |
None.
All command modes.
This example shows how to reset the PoE management mode to “realtime” on module 1:
System(rw)->clear inlinepower management 1
Print
this page
Email this topic
Feedback
