Use this command to configure OAM link monitor functionality for the specified port.
| port-string | Specifies the port(s) to enable or disable. For a detailed description of possible port-string values, refer to Port String Syntax Used in the CLI in the S-, K-, and 7100 Series Configuration Guide. |
| frame | Configure OAM monitoring of frame events for a port. |
| frame-period | Configure OAM monitoring of frame-period events for a port. |
| frame-seconds | Configure OAM monitoring of frame-second events for a port. |
| symbol-period | Configure OAM symbol-period event for a port. |
| threshold threshold | Specifies the number of errors threshold for the specified OAM link monitor function. See the Usage section of this command for default and range threshold values for each link-monitor function. |
| window window | Specifies the window value for:
See the Usage section of this command for default and range window values for each link-monitor function. |
| syslog | Specifies that a syslog message will be generated upon detecting a link monitor event. |
| disable-interface | Specifies that the port will be operationally disabled upon detecting a link monitor event. |
| notify | Specifies that a link notification event is triggered upon detecting a link monitor event. |
None.
All command modes.
This command configures the link-monitoring process on the specified port. Should the number of errors exceed the value specified in the threshold parameter for the configured window parameter, the link-monitoring process will take one or more specified actions.
If the threshold value is zero (0), then an Event Notification OAM PDU is sent at the end of every window, regardless of whether the threshold is exceeded or not for that window. This can be used as an asynchronous notification to the peer OAM entity of the statistics related to this threshold crossing alarm.The frame option monitors frame errors occurring during a period of time. The default threshold is 1 errored-frame. Valid threshold values are 0 - 4294967295 errored-frames. The default window is a 1 second interval. Valid window values are 1 - 60 seconds.
The frame-period option monitors frame errors that occur during the reception of a given number of frames. The default threshold is 1 errored-frame. Valid threshold values are 0 - 4294967295 errored-frames. The default window is equivalent to the maximum number of minimum sized frames that may be transmitted over the link during a one second interval, and the upper bound is the maximum number of minimum sized frames that may be transmitted over the link during a one minute interval. Therefore, the maximum frame-period window value can be set to 60 times the default window value.
The frame-period option defines its window value (number of frames) based upon the line rate of the port being configured. As such, the value may not be determined until the port has achieved a valid link state. The possible frame-period window default and range values, based upon link speed are displayed in Frame-Period Window Values.
| Port Line Rate | Default Window Value | Window Value Range |
| 100 Mbps | 148,800 frames | 14880 - 8928000 frames |
| 1Gbps | 1,488,000 frames | 148,800 to 89,280,000 frames |
| 10 Gbps | 14,880,000 frames | 1,488,000 to 892,800,000 frames |
The frame-seconds option monitors the number of one-second intervals in which one or more frame errors occurred. The default threshold is 1 errored-second. Valid threshold values are 0 - 4294967295 errored-seconds. The default window is 60 seconds, the minimum is 10 seconds, and the maximum is 900 seconds.
The symbol-period option monitors symbol errors that occur during the reception of a given number of symbols. The default threshold is one errored-symbol. Valid threshold values are 0 - 4294967295 errored-symbol. The default window is equivalent to the maximum number of symbols that may be transmitted over the link during a one second interval, and the upper bound is the number of symbols that may be transmitted over the link during a one minute interval. Therefore, the maximum symbol-period window value can be set to 60 times the minimum window value.
The symbol-period option defines its window value based upon the line rate of the port being configured. As such, the value may not be determined until the port has achieved a valid link state. The possible symbol-period window default and range values, based upon link speed are displayed in Symbol-Period Window Values.
| 100 Mbps | 131,072,000 symbols | 52,428,800 - 7,864,320,000 |
| 1Gbps | 524,288,000 symbols | 524,288,000 - 31,457,280,000 |
| 10 Gbps | 5,242,880,000 symbols | 5,242,880,000 - 314,572,800,000 |
The administrator may configure any one of three actions to be taken upon the detection of a link event:
This example shows how to set the OAM link monitor frame threshold to 1, window to 300 seconds, and action to syslog for port ge.1.3:
System(rw)->set port oam ge.1.3 link-monitor frame threshold 1 System(rw)->set port oam ge.1.3 link-monitor frame window 300 System(rw)->set port oam ge.1.3 link-monitor frame action syslog System(rw)->
This example shows how to set the OAM link monitor frame-period threshold to 1, window to 500000, and action to disable the interface, generate a syslog message and send a link notification:
System(rw)->set port oam ge.1.3 link-monitor frame-period threshold 1 System(rw)->set port oam ge.1.3 link-monitor frame-period window 500000 System(rw)->set port oam ge.1.3 link-monitor frame-period action disable-interface syslog notify
Print
this page
Email this topic
Feedback
